Jump to content
Russian Mustang Club
Sign in to follow this
Richmond
Установка myColor и кнопок управления - нужна помощь.
Recommended Posts
Richmond
Коллеги, нужна помощь!) Приобрел приборку myColor и блок кнопок управления. Все воткнул все работает, ОДНАКО, не нашел фишки под блок управления.
Подскажите, пожалуйста, кто менял у себя, где может данная фишка лежат (ибо по опыту других машин все фишки лежат уже с завода в одной косе. Если нету - поделитесь схемами, чтобы электрик мог нарастить провода. Спасибо!
Share this post
Link to post
Share on other sites
Richmond
Вот что нашел:
I was looking over the schematics for the message center switch and they are wired directly to the instrument cluster except for one wire that goes to the SJB for illumination. If you are the hack/mod type you should be able to make your own harness. Another option is to go to a bone yard and get the harness. I've had one person so far try this with success. You do have to splice into the ground wire and according to the schematic there is a splice point at S201 or you could tie into another ground. I already have mycolor so I didn't have to do this mod but thought there might be others who want to do this mod.
Parts provided by Kevin Casey and other members
PigTail connector: Motorcraft Part # WPT-554
Info/Setup/Reset: Ford Part # 4r3z10d889aaa or 6r3z18578aa
Pins to plug into Inst Cluster/SJB: ???????
Mycolor/GT500 Clusters: Check with your local dealer
The schematic PDF is 150k so since it is outside the posting limit here's a link.
I went to a junk yard and found the switch and cut the wiring back as far as i could, so I would have the connector to the switch and then I cut the plug from the speedometer. With these I was able to pull out the two wires from the connector that goes to the speedometer and add them to the connector of my cars connector along with extra wire to the connector of the switch that controls the message center. You can find a copy of the wiring by searching for my color.
    Edited by Richmond
    Share this post
    Link to post
    Richmond
    Разобрался.
    Если коротко: на кнопках 4 контакта:
    1. -> + подсветки 4. -> - подсветки
    2. надо соединить с 6 контактом фишки на приборке
    3. надо соединить с 7 контактом фишки на приборке
    все заработает. Как сделаю - будет отчет.
    Share this post
    Link to post
    Beard00
    Кто знает, можно ли проборку от 12 года (С дисплеем) воткнуть в 2010 (Переходная движок уже 3,7)??
    Share this post
    Link to post
    Join the conversation
    You can post now and register later. If you have an account, sign in now to post with your account.
    Guest
    Reply to this topic...
    ×   Pasted as rich text.   Paste as plain text instead
      Only 75 emoji are allowed.
    ×   Your link has been automatically embedded.   Display as a link instead
    ×   Your previous content has been restored.   Clear editor
    ×   You cannot paste images directly. Upload or insert images from URL.
    Loading...
    • Create New...
