Pratas Опубликовано 20 Сентября 2008 Жалоба Опубликовано 20 Сентября 2008 (изменено) Значится разобрался я со спецификациями фода на антифризы. Спасибо человеку с ником wit-65 с профилированной конференции по автохимии. Им была данна вот такая ссылочка :http://www.search-autoparts.com/searchauto...e/detail/329982========================Ford's Position On Universal Coolants Some companies market a universal coolant, stating that their product can be used for all vehicle applications. Here is Ford Motor Company's official policy on these products.Q: What is Ford's position on the use of "universal" coolants in Ford vehicles?A: Ford does not have performance data for the multitude of engine coolants available in the aftermarket and therefore cannot recommend the use of any coolant except those approved by Ford Motor Company. Due to the complexity of cooling systems, no one coolant has been proven to work in all vehicles. "Universal" coolants generally do not contain silicates and nitrites, both of which are required for Ford vehicles equipped with Motorcraft Premium Gold Engine Coolant. Thus, these "universal" coolants generally do not meet Ford's coolant specification WSS-M97B51-A1.Ford vehicles equipped with Motorcraft Premium Engine Coolant, meeting Ford specification ESE-M97B44-A, require silicates and, in the case of diesel engines, the use of Motorcraft Diesel Cooling System Additive, VC-8, which contains nitrites. Thus, these "universal" coolants may not be suitable for use in vehicles originally equipped with Motorcraft Premium Engine Coolant.Based on blind laboratory ASTM testing performed in duplicate, two leading "universal" coolants currently in the marketplace did not meet the extended D2809 requirements of Ford's Motorcraft Premium Gold Engine Coolant specification, WSS-M97B51-A1.The "universal" coolants may not be compatible with Ford's recommended supplemental coolant additive, Motorcraft Diesel Cooling System Additive, VC-8.Use of non-approved "universal" coolants may lead to eventual engine damage or failure. Problems caused by use of non-approved "universal" coolant may not arise immediately, but may occur over longer periods of time due to additive compatibility issues.Although the Ford New Vehicle Limited Warranty is not automatically voided upon the use of a non-approved coolant in Ford vehicles, if such use results in damage to the vehicle or its components, the cost of repairing the damage (and related damage) would not be covered by the Ford New Vehicle Limited Warranty.50%As many as 50% of all headlamps on the road may be misaimed. Every vehicle that comes into a shop should have its headlamps checked.(Source: AAA Foundation) Q. What may be some of the consequences of using the wrong coolant?A: These include: * Reduced corrosion protection of cooling system components.* Incompatibility with engine gasket materials.* Corrosive attack of aluminum components.* Cylinder wall cavitation and engine block damage in diesel engines.* Potential water pump issues. Q: What are the primary coolant types Ford recommends for use in its vehicles?A: Reference the Service Coolant Usage Chart for specific vehicle usage information: * Yellow-colored Motorcraft Premium Gold Engine Coolant, meeting Ford specificationWSS-M97B51-A1. * Green-colored Motorcraft Premium Engine Coolant, meeting Ford specification ESE-M97B44-A. * Orange-colored Motorcraft Specialty Orange Engine Coolant, meeting Ford specification WSS-M97B44-D.=============================Получается что все марки антифриза указываемые нашими "порядочными" продавцами на одной канистре в ряд - банальный обман. Мало того что продадут, так ещё и бессовестно заверят что всё в порядке - лей и катайся. Лично мне кажется что заливать в машинку надо именно то что указанно в мануале производителем, а не примерно подбирая по рекомендациям в магазинах. Именно по этому при смене антифриза на другую марку целиком выливая старый ... можно себя успокоить что поменял и всё отлично - но мне кажется хим свойства у антифризов весьма разняться и это безусловно повлияет на сиситему охлаждения двигателя, не сразу но повлияет. Хотя дело каждого что лить и кого слушать Изменено 20 Сентября 2008 пользователем Pratas Цитата
BORT044 Опубликовано 20 Сентября 2008 Жалоба Опубликовано 20 Сентября 2008 Круто! А как именно, повлият? Что произойдёт? Насколько изменится ресурс системы охлаждения? Каковы сроки службы помпы, патрубков, рубашки охлаждения при применении различных антифризов? Тема не раскрыта! Цитата
DoctorM Опубликовано 20 Сентября 2008 Жалоба Опубликовано 20 Сентября 2008 А есть ли смысл докапываться до этих деталей. Черным по белому: остальные марки "универсальных" антифризов несовместимы с рекомендуемым производителем. Зачем разрывать себе моск? Цитата
Soto Опубликовано 20 Сентября 2008 Жалоба Опубликовано 20 Сентября 2008 (изменено) Q: What are the primary coolant types Ford recommends for use in its vehicles?A: Reference the Service Coolant Usage Chart for specific vehicle usage information: * Yellow-colored Motorcraft Premium Gold Engine Coolant, meeting Ford specificationWSS-M97B51-A1. * Green-colored Motorcraft Premium Engine Coolant, meeting Ford specification ESE-M97B44-A. * Orange-colored Motorcraft Specialty Orange Engine Coolant, meeting Ford specification WSS-M97B44-D.Респект! Спасибо!В догонку:Ford (Motorcraft) sells yellow, green and orange coolants. From the Motorcraft website: "Premium Engine Coolant- Green-colored, conventional, ethylene glycol based, universal formulation for use in gasoline and diesel engines - Approved for engines with aluminum radiators and/or aluminum heads as well as conventional engines - Provides year-round antifreeze, antiboil and corrosion protection - Provides year-round protection in both hot and cold climates. Provides -35°F winter to over 250°F summer system protection when used in the recommended 50% mix with - Do not use in model year 1999 and forward Cougar and Electric Vehicle Ranger - Do not mix this coolant with systems originally equipped with any orange-colored, extended-life coolant such as Motorcraft? Specialty Orange Engine Coolant, meeting Ford Material Specification WSS-M97B44-D or the yellow-colored, extended-life coolant Motorcraft? Premium Gold Engine Coolant, meeting Ford Material Specification WSS-M97B51-A1 Premium Gold Engine Coolant- Yellow-colored, extended-life, ethylene glycol based engine coolant for use in gasoline and diesel engines - Provides year-round antifreeze, antiboil and corrosion protection - Only use where specified. Do not mix this product with systems originally equipped with any green-colored, conventional engine coolant such as Motorcraft? Premium Engine Coolant, meeting Ford Material Specification ESE-M97B44-A or any orange-colored,extended-life engine coolant such as Motorcraft? Specialty Orange Engine Coolant, meeting Ford Material Specification WSS-M97B44-DSpecialty Orange Engine Coolant- Orange-colored, ethylene glycol based, extended life coolant - Protects water pump seals and provides high temperature aluminum protection - For use in specified MY 1999 and forward Cougar and Ford Electric Vehicle Ranger - Use only where specified. Do not mix this product with systems originally equipped with any green-colored, conventional engine coolant such as Motorcraft? Premium Engine Coolant, meeting Ford Material Specification ESE-M97B44-A or the yellow-colored, extended-life engine coolant Motorcraft? Premium Gold Engine Coolant, meeting Ford Material Specification WSS-M97B51-A1" Изменено 20 Сентября 2008 пользователем Soto Цитата
Pratas Опубликовано 20 Сентября 2008 Автор Жалоба Опубликовано 20 Сентября 2008 Да да ... именно так. Хорошо что этот вопрос не меня одного волнует, как оказалось Цитата
Edward Lee Опубликовано 7 Октября 2008 Жалоба Опубликовано 7 Октября 2008 Я решил пользовать вот этот,- Chevron Custom-Made Antifreeze/Coolant Универсальная охлаждающая жидкость желтого цвета(эт как у меня залита) на основе этиленгликоля,выпускаемая по запатентованной Chevron карбоксилитной технологии. Специально разработанная согласно требованиям для новых моделей Ford и Chrysler. В состав данного антифриза с пониженным содержанием кремнекислых солей не входят фосфаты,в связи с чем обеспечивается эффективная защита всех металлических деталей охлаждающей системы автомобиля. Продленный срок службы до 5 лет или 100 000 миль(160 900 км). Пониженное содержание кремнекислых солей и отсутствие в составе фосфатов помогает продлить срок службы помп. Изготавливается по заказу компаний Ford и Chrysler для новых моделей автомобилей. Допуски и спецификации: Ford North America WSS-M97B51-A1, Chrysler MS-9769 и т.д. Цитата
biven Опубликовано 7 Октября 2008 Жалоба Опубликовано 7 Октября 2008 (изменено) и да будет тебе счастье.................... Миш, мне кажеццо ты ерундой .............. а баночки красивые, но без коников Изменено 7 Октября 2008 пользователем biven Цитата
Pratas Опубликовано 7 Октября 2008 Автор Жалоба Опубликовано 7 Октября 2008 да я пока не стал ничего менять ... по весне буду запариваться Цитата
Kai Опубликовано 5 Декабря 2008 Жалоба Опубликовано 5 Декабря 2008 (изменено) Я эту спецификацию на всех наших американских форумах прочитал но так и не понял че лить то? Заказывать моторкрафт через магазин или же брать шеврон и не париться ? Изменено 5 Декабря 2008 пользователем Kai Цитата
Soto Опубликовано 5 Декабря 2008 Жалоба Опубликовано 5 Декабря 2008 Я эту спецификацию на всех наших американских форумах прочитал но так и не понял че лить то? Заказывать моторкрафт через магазин или же брать шеврон и не париться ?А машинка в твои руки из штатов пришла? Цитата
Kai Опубликовано 5 Декабря 2008 Жалоба Опубликовано 5 Декабря 2008 (изменено) А машинка в твои руки из штатов пришла?Нет.... уже успела не один год поездить у нас тут Изменено 5 Декабря 2008 пользователем Kai Цитата
