  Mus500 писал(а):
Ошибка 0507 высокие обороты.... С чем может быть связано???
P0507 - Idle Air Control System RPM Higher Than Expected
Causes.
A P0507 DTC trouble code may be caused by one or more of the following:
A vacuum leak
Leaking air intake after the throttle body
EGR valve leaking vacuum
A faulty positive crankcase ventilation (PCV) valve
Damaged/failed/dirty throttle body
Failed EVAP system
Failed IAC (idle air controller) or faulty IAC circuit
Лишний воздух где-то сосет...
