Допуски на толщину тормозных дисков на FOX
Товарищи!! откликнетесь!! Какая остаточная толщина (минимум) в допусках на Мустангах *90- х годов?
Section 06-03: Brakes, Front Disc
1993 Mustang Workshop Manual
SPECIFICATIONS
Specifications
FRONT DISC BRAKE DIMENSIONS
Component Mustang 5.0L Mustang 2.3L
Lining Material Eyelet Riveted Riveted
Lining Size Outer 162 x 45.4mm (6.38 x
1.79 inch)
Inner 136.9 x 47mm (5.39 x
1.85 inch)
151 x 50mm (5.92 x 1.97 inch)
120 x 59mm (4.74 x 2.32 inch)
Lining Wear Limit (From Shoe Surface) 3.175mm (.125 inch) 3.175mm (.125 inch)
Lining to Rotor Clearance (Brakes Released) 0.0-25mm (0.0-0.10 inch) 0.0-25mm (0.0-010 inch)
Caliper Cylinder Bore Diameter 72.9mm (2.87 inch) 60mm (2.36 inch)
Master Cylinder Bore Diameter 25.5mm (1.125 inch) 21mm (0.827 inch)
Front Rotor Nominal Thickness 26mm (1.03 inch) 22mm (0.870 inch)
Front Rotor Minimum Thickness1 24.68mm (0.972 inch) 20.574mm (0.810)
Front Rotor Diameter 277mm (10.91 inch) 256mm (10.08 inch)
Front Rotor Allowable Runout 0.07mm (0.003 inch) 0.07mm (0.003 inch)
Front Rotor Finish 15-125 micro-inches 0.4-3.2 micro meters (10-81 micro inches)
Front Rotor Thickness Variation 0.013mm (0.0005 inch) 0.013mm (0.0005 inch) (Steel Wheels)
1 Minimum Safe Thickness is shown on each Rotor.
TORQUE SPECIFICATIONS
Description Nm Lb-Ft Lb-In
Flexible Brake Hose to Caliper Fitting—2.3L 27-41 20-30
Brake Hose to Caliper Bolt—
5.0L
40-60 26-44
Caliper Locating Pins 61-88 45-65
Brake Tube to Hose Fitting 14-24 10-18
Splash Shield Bolts—5.0L 12-19 9-14
Splash Shield Bolts—2.3L 15-16 11-12
Wheel Lug Nuts 115-142 85-105
Brake Hose to Caliper Assembly 27-40 20-30
Adjusting Nut 24-33 17-25
Bleeder Screw 14-16 116-148 (Lb-In)
Section 06-04: Brakes, Rear Disc
SPECIFICATIONS
Specifications
BRAKE DIMENSIONS
Description Specification Metric (U.S.)1
Lining Material Riveted Organic
Lining Size Inner and Outer 99.4 x 38.5
(3.91 x 1.52)
Lining Wear Limit (From Shoe Surface) 3.12 (0.123)
Caliper Cylinder Bore Diameter 45.44 (1.789)
Rear Rotor Nominal Thickness 24 (.945)
Rear Rotor2 Minimum Thickness 22.75 (.895)
Rear Rotor Diameter (Inner) 175 (6.89)
Rear Rotor Diameter (Outer) 258 (10.16)
Rear Rotor Allowable Runout 0.08 (0.003)
Rear Rotor Finish3 3.2/0.4μm (16-25μ in.)
Rear Rotor Thickness Variation 0.013 (0.0005)
1 mm (inches) unless specified.
2 Minimum safe thickness is shown on each rotor.
3 μm micrometer (μ in. micro inches)
Parking Brake Cable Retaining Screw 22-29 16-22
Flex Hose-to-Caliper Retaining Bolt 24-32 18-24
Anchor Plate Retaining Bolts 87-119 64-88
Splash Shield Retaining Screws 8-12 6-9
Axle Adapter Retaining Bolts 27-54 20-40
Parking Brake Cable Bracket-to-Caliper 31-35 23-26
Slider Pin Pinch Bolt 40-47 30-35
Parking Brake Lever Limiting Bolt 6-9 4.5-7
Section 06-02: Brakes, Rear Drum
SPECIFICATIONS
Specifications
Wheel Cylinder-to-Backing Plate Bolts 14-28 10-20
Rear Brake Backing Plate to Axle Housing 28-54 20-39
Wheel Cylinder Bleeder Screw 3.6-7.3 32-65 (Lb-In)
Tube Fitting Nut 14-24 10-17
BORE DIAMETERS—BRAKE DRUM AND WHEEL CYLINDER
Brake Drum Rear Wheel Cylinder
Bore Diameter
Inside Diameter Boring Limit (Max.)1 Rear2
9.000 9.060 0.750
1 Max. Runout 0.007
2 Max. Allowable Hone 0.003
Vehicle Brake Size Position Color Code Lining Size
All 9 Primary
Secondary
Orange/Yellow
Gray/Yellow
1.75 x 6.10
1,75 x 8.65
