Teen_Spirit Опубликовано 15 Августа 2010 Жалоба Опубликовано 15 Августа 2010 Итак, дождались! Ford Mustang Boss 302: Oh Yes!Sun, Aug 15, 2010Automotive News, DebutsFord Mustang Boss 302: Oh Yes!One thing the world has no shortage of is limited-edition Mustangs. I?m not sure they make numbers high enough to count how many ?special? Mustangs there have been over the years, but it?s somewhere between ?A gazillion? and ?X, where X=enough+1.? What?s a shame is that most of them are nothing more than silly tape-and-stickers packages. GT/California Special? Vinyl decals and some nice wheels. Shelby GT? Loud exhaust, filter-on-a-stick, a $10,000 Shelby badge and some chrome hood pins. Bullitt? A Mustang GT with less of the tacky Mustang GT stuff stuck on it. Just fabricated specialness that any gearhead can see through at first glance.So when rumors started circulating that Ford would be bringing back the ?Boss? Mustang moniker, I didn?t get my hopes up. I was expecting more of the same tape-and-stickers shenanigans, with the end result of a Mustang that?s not better, just goofier looking and more expensive. Thankfully, I seem to be wrong.For those of you that didn?t live through the sixties, or don?t remember them (some say if you remember them, you weren?t there!) this is not the first time that ?Boss 302″ has been etched on the side of a particularly nasty Mustang. The first Boss 302 (and big brother Boss 429) Mustangs were introduced in 1969, as a road-going homologation special for Trans-Am racing. To keep up with the more powerful Camaro Z/28′s, the Boss 302 used a high-compression, high-winding V8 that was a mixture of Windsor and Cleveland parts with worked heads, a free-breathing exhaust, and beefed up valvetrain and cooling to support race duty. While the big-block Boss 429 was homologated for roundy-roundy stock car racing, the lighter and more responsive Boss 302 endowed the Mustang with serious track presence, especially with the competition-style suspension and braking hardware. It was the car that put the name ?Parnelli Jones? on the map. And it?s back. Oh yes.As you?re probably sick of hearing by now, the 2011 Mustang GT heaved out the ancient single-cam 3v 4.6L Modular V8 in favor of a (mostly) brand new all-aluminum 5.0L 32v V8. Which means that once again, the Mustang has a 302 under the hood. And the standard model?s no slouch -- 412bhp/390lb-ft of torque, a 6-speed manual transmission, low four-second 0-60 times. The new Boss 302 is designed to fit in the Mustang lineup between the impressive GT 5.0 and the absurd supercharged GT500, and on paper it seems to do that to great effect.Things have been fiddled with properly under the hood. The 5.0L engine?s output jumps from 412bhp to 440bhp, and torque drops from 390 to 380lb-ft. The change in output and character are down mainly to two modifications: a new high-volume intake manifold, and more aggressive cam profiles combined with a reprogramming of the Ti-VCT cam phasing system. Ford powertrain engineers say the changes were designed to increase top-end power without sacrificing driveability or a smooth idle, as the Boss 302 is intended for street or track use.The drivetrain is equally impressive. The 6-speed manual is actuated through a short-throw shifter, the final-drive ratio is raised to 3.73:1 for stronger acceleration, and the rear differential has carbon-fibre plates for longevity. Interestingly, a Torsen (Torque-Sensing) reactive rear limited slip diff is available packaged with Recaro seats, which seems like a good choice.They?ve also done a lot of work with the exhaust system. The Boss 302 has a ?quad exit? setup, which brings back memories of the Mitsubishi VR-4′s ?variable exhaust note? system. The Boss has 2 exhaust outlets out back as well as two on the side, and the flow of exhaust gasses is controlled by a series of metal discs -- so most of the gasses come out the back, but you still get a nice amount of noise out the sides as well. Even more interesting is that Ford Powertrain expects owners to say ?Frog that, sidepipes!? and the system is configurable for full side-exit action for ?off road use only.? You know, computer generated, filmed on a closed road in Mexico, professional drivers do-not-attempt-at-home, wink wink nudge nudge.Of course, it wouldn?t be a Boss Mustang if they just threw a bunch of parts at the motor and called it a day. It?s got to go ?round corners too! It?s got the typical suspension modifications -- higher springs rates at all four corners, lower static ride height, stiffer bushings, and a larger rear anti-roll bar. What?s really intriguing are the 5-setting adjustable dampers at each corner. Most adjustable dampers are a major pain in the rear to actually adjust -- usually you have to jack up the corner to unload the shock, pull out your bespoke perch tool, and fiddle with the damper in the fender well for ten minutes -- and that?s if you don?t have to remove the shock to adjust it in the first place! However, the dampers on the Boss are adjustable at the top of the shock towers on all four corners -- all you need is a straight screwdriver. Leave ?em at 2 for daily driving, crank ?em up to 5 for track duty, then put ?em back down to 1 for highway cruising. Why isn?t everything this simple?As far as rolling stock and anchors go, the Boss 302 sports some serious rubber: 19″ lightweight wheels all around, 9″ wide in the front and 9.5″ wide in the rear. All four corners are shod with Pirelli PZero?s (255/40 front, 285/35 rear) for maximum grip on a street tire. Braking duties are handled by 14″ Brembo rotors clamped by 4-piston calipers up front, while standard GT rear brakes get more aggressive pads. The Boss 302 uses braided brake lines to eliminate flex for better stopping power and modulation.It appears the Boss 302 has going fast covered, and of course it?s also got looking fast covered as well. It?s going to be hard to not notice one of these driving by, even if it didn?t have blaring side-pipe exhausts. The Boss gets a black-or-white colored roof panel matched to the C-stripe on the side, as well as an aerodynamic front splitter and rear spoiler. The foglight housings are blocked off, too. You can get a Boss 302 in any color you want, as long as it?s obnoxious: Competition Orange, Performance White, Kona Blue (my choice), Yellow Blaze Tri-Coat, and Race Red.Inside, the Boss 302 gets the goods as well. Along with the aforementioned optional Recaro seats shared with the GT500, there?s an Alcantara-lined steering wheel, dark metallic finish on the IP and doors, and a black 8-ball shift knob. Even more important: Ford?s ripped out 11 pounds of sound deadening so you can actually hear how awesome that motor sounds.How does it all add up? Well, Ford says the Boss 302 is at least 2 seconds a lap faster around a race track than the standard GT 5.0, which is obviously no slouch. They say it?ll lap Laguna Seca faster than a 2010 M3, as well. And if all this isn?t enough, there will be a limited production run Boss 302 Laguna Seca edition, which has greater body rigidity, a stiffer suspension setup, and the full aero package from the race-prepped Boss 302R cars that FRP campaigns.As is the norm with debuts like these, no pricing or availability information has been announced. But since the car is labelled as a 2012 model, a good bet would be summer of next year when they start showing up in showrooms. So if you want a Mustang with more of an attitude, but don?t want a giant sledgehammer of a car like the GT500, it?d probably be a good idea to get your deposit in now. Цитата
Арсений Опубликовано 15 Августа 2010 Жалоба Опубликовано 15 Августа 2010 Выпуск очень интересный Цитата
avrb Опубликовано 15 Августа 2010 Жалоба Опубликовано 15 Августа 2010 это чтобы переключать- тихий режим или громкий... Цитата
Camel Опубликовано 15 Августа 2010 Жалоба Опубликовано 15 Августа 2010 Меня чето не особо прет... Цитата
Romka Опубликовано 15 Августа 2010 Жалоба Опубликовано 15 Августа 2010 А мя прет!!!! Тока вот сцепу пусть доделают (извини за подъёб, Саня, я по-доброму)) Ну, и, ваще, хороший подарок человечеству в канун Конца Света )) Цитата
Serg93 Опубликовано 15 Августа 2010 Жалоба Опубликовано 15 Августа 2010 Итак, дождались! Супер!!! Цитата
Арсений Опубликовано 15 Августа 2010 Жалоба Опубликовано 15 Августа 2010 это чтобы переключать- тихий режим или громкий... Дык клапанов-то как раз и не видно! Цитата
mironov Опубликовано 16 Августа 2010 Жалоба Опубликовано 16 Августа 2010 С маркетингом у Форда всегда было все хорошо.. ну, почти всегда. Цитата
koss Опубликовано 16 Августа 2010 Жалоба Опубликовано 16 Августа 2010 С маркетингом у Форда всегда было все хорошо.. ну, почти всегда.Ой как хочется..., но сейчас только мечтать... (( Цитата
Pratas Опубликовано 16 Августа 2010 Жалоба Опубликовано 16 Августа 2010 Ford Mustang Boss 302 вернется в 2012 модельном году Многолетняя мечта поклонников спорткара Ford Mustang сбылась ? модель Boss 302 образца 2012 года анонсирована официально. Представлял ее никто иной, как главный инженер Mustang Дэйв Перикак. "Прежде чем вновь дать Mustang легендарное имя Boss, мы должны были убедиться, что у него есть все для того, чтобы стать достойным преемником этой машины. Нужно было либо сделать машину правильно, либо не делать ее вообще, так как никто из нас не собирался просто ставить на нее новые колеса и наклеивать шильдик Boss", - отметил он.И действительно, Boss 302 должен быть грубым, бескомпромиссным и вдохновленным гонками. К этой последней специальной версии все вышеперечисленное относится в полной мере. Так, новый пони-кар получил в свое распоряжение усовершенствованное сцепление, короткоходный рычаг коробки передач, регулируемую подвеску, улучшенные тормоза и более мощную версию пятилитрового V8, который в данном случае развивает 440 лошадиных сил и 515 Нм крутящего момента. Увеличение потенциала стало возможным благодаря модификации системы впуска и установке агрессивных распредвалов.Согласно заявлению производителя, на типичном гоночном треке Boss 302 на две секунды быстрее стандартного Mustang GT. Более того, при разработке спорткара американцы взяли за эталон BMW M3 и постарались сделать так, чтобы новинка была быстрее его на автодроме Laguna Seca. Этой цели им, в конце концов, и удалось достичь.Внешность машины навеяна образом оригинальной модели 1969 года, она имеет такую же белую или черную крышу, фирменные полосы на кузове, закрытые оправы противотуманных фонарей, а также более агрессивный передний сплиттер и задний спойлер. Доступен и ряд уникальных вариантов окраски: желтый Competition Orange, белый Performance White, синий металлик Kona Blue Metallic, желтый металлик Yellow Blaze Tri-Coat Metallic и красный Race Red.Салон лишился пяти килограммов звукоизоляционных материалов, приобретя взамен выкрашенные в темно-металлический цвет приборы, дверные панели и приборную доску. Рулевое колесо обшито синтетической замшей, а за дополнительные деньги можно заказать спортивные кресла Recaro. Наконец, Ford также планирует выпустить ограниченную серию Mustang Boss 302 Laguna Seca с более жестким кузовом, укрепленным шасси и аэродинамическим обвесом от Ford Racing Boss 302R. Цитата
AlexStup Опубликовано 17 Августа 2010 Жалоба Опубликовано 17 Августа 2010 О да, детка! P.s. ушел трудится 25 часов в сутки. Цитата
Teen_Spirit Опубликовано 18 Августа 2010 Автор Жалоба Опубликовано 18 Августа 2010 (изменено) Если он будет стоить на 5-7 тысяч дороже моего Койота, то я отгрызу себе оба локтя. Хотя, ИМХО, судя по проделанным переделкам и трековым анонсам, он должен дороже Шелби стоить.ЗЫ: Тема уже есть такая=) http://www.mustangclub.ru/forum/index.php?showtopic=8803 Изменено 18 Августа 2010 пользователем Teen_Spirit Цитата
Essensi Опубликовано 18 Августа 2010 Жалоба Опубликовано 18 Августа 2010 Ford Mustang Boss 302 вернется в 2012 модельном году .... Наконец, Ford также планирует выпустить ограниченную серию Mustang Boss 302 Laguna Seca с более жестким кузовом, укрепленным шасси и аэродинамическим обвесом от Ford Racing Boss 302R.Посмотреть бы на этот обвес. Цитата
Naz Gul Опубликовано 18 Августа 2010 Жалоба Опубликовано 18 Августа 2010 Ты наверное хотел сказать "Посмотреть бы на этот обвес зимой в России". Так-то на фотке именно он. Цитата
MiDiM Опубликовано 18 Августа 2010 Жалоба Опубликовано 18 Августа 2010 По моему с окраской не совсем удачно... А вообще, зачетный болид! Цитата
Unicum Опубликовано 10 Сентября 2010 Жалоба Опубликовано 10 Сентября 2010 Обвес на переднем бампере лишний, это же америкос, а не японец... Цитата
Naz Gul Опубликовано 10 Сентября 2010 Жалоба Опубликовано 10 Сентября 2010 (изменено) Обвес на переднем бампере лишний, это же америкос, а не японец...Что-то мне подсказывает, что это не для эстетической красоты сделано, а гоночного перфоманса для, поэтому такой пафос здесь неуместен. Изменено 10 Сентября 2010 пользователем Naz Gul Цитата
