Артифас Опубликовано 21 Апреля 2015 Жалоба Опубликовано 21 Апреля 2015 Появился мотор от FOX 2.3. Интересна переделка его в турбо 2,3.Визуально моторы отличаются коллекторами,зажиганием- у турбомотора распределитель стоит а у моего ДПК,клапанной крышкой ну и соответственно электрикой.Судя по мощности атмо двигла появилось мысль что это надутый мотор с которого просто открутили наддув.Хотелось узнать у экспертов что по внутрянке? Ведь клапаны и шатуны должны отличаться у мотора в 100 и почти в 200 сил? Цитата
root Опубликовано 21 Апреля 2015 Жалоба Опубликовано 21 Апреля 2015 You can install a turbo on a N/A 2.3 but don't turn the boost up past 5-6 psi. If you do, the pistons will disinegrate! And, even running that low psi, they probably won't last very long anyway! True turbo motors came from the factory with forged pistons. Forged pistons will take the heat and pressure of forced induction. N/A pistons are made of cast metal. They're very brittle and simply can't take the heat and pressure. So, if you're going to rebuild your motor, simply replace the cast pistons with forged units. You'll also need to fabricate some sort of oil drainback for the turbo. Oil is fed into the center section of the turbo from the top, circulates and drains back into the oil pan. 2.3 turbo blocks have a threaded drainback hole thats tapped into the block just above the oil pan to accomplish this task. If you have a bare N/A block, you can drill and tap this boss in the block and acquire the appropriate brass fitting to screw into it. The fitting can be found on any turbo block in the junkyard and occasionally they're for sale on Ebay. Another alternative is to tap into the oil pan, above the oil line and run a hose from the bottom of the center section to the pan. That's it for the actual shortblock. True turbo heads have a different combustion chamber and port configuration than N/A heads along with exhaust valves made from a stronger metal known as Iconel.Turbo motors use a Vane Air Meter and larger 35# fuel injectors for fuel and air delivery. Both can be found in the junkyard or on Ebay. To provide the appropriate amount of fuel to the injectors along with the correct metering of air, you'll need the right computer. An LA2 or LA3, found in '87-'88 Thunderbird TurboCoupes with 5-speeds is the one you want. An LB2, LB3 and PE will also work. The LB series is for TC's with automatics and the PE, the most aggressive of all computers, is found in the Mustang SVO. The computers themselves are easily swapped. You'll also have to repin the wiring harness computer connector. Most people give up here because it sounds like such a daunting task! It's probably the simplest procedure in the whole swap. There are several websites that give you step by step instructions. In addition, you'll need either a factory or aftermarket boost controller to control your boost pressure. A good idea would be to add a 255 lph fuel pump to provide the additional fuel that's needed. Too many turbo applications have died due to lean conditions!By far the cheapest, most thorough and simplest way to add a turbo to your N/A Mustang is to purchase a donor car and swap everything over. The first choice would be a '87-'88 Thunderbird TurboCoupe. They come with a factory 195 hp turbo'd 2.3, T5 and 8.8 rearend with disc brakes and 3.55:1 gears. All this can be easily swapped into a Mustang. In addition, you'll have everything you need along with a zillion nuts, bolts, fasteners, etc. There are many other parts that can be swapped into a Mustang as well. Interior pieces, suspension pieces, brakes, the list is endless. Here's the kicker. '87-'88 TC's are a dime a dozen, at least on the West Coast. $500 will get you a good running, high mileage TC. And as you know, 2.3's are pretty much bulletproof! The iceing on the cake is, what you don't use on your project, you can resell on Ebay or any of the message boards dedicated to 2.3 turbos. There's a good sized market out there for used TC parts. Your $500 will be recouped in no time!If you can't find a '87-'88 TC, the next best thing would be a '83-'86 TC, followed by an '85-'89 Merkur XR4ti. There are turbo Cougars out there that are also good candidates. I believe '85-'86 are the years for them. Of course an SVO would be the ultimate! However, they're pretty rare and you probably wouldn't want to part one out. Below is a list of websites of both vendors and just regular Turboforders that offer tons of information. I hope this addressed some of the basic questions of turboing a N/A 2.3. It really isn't a very hard swap. If you have some basic mechanical ability and a good set of handtools, you can easily perform this swap. You'll learn a few things along the way and the sense of accomplishment you'll acquire will make it all worthwhile. Oh, and you'll be amazed at how quick you car is gonna be!List of websites:www.stinger-performance.com - wiring conversionwww.flemworld.com - wiring conversionwww.turboford.net - turbo 2.3 websitewww.turbotbird.com - TurboCoupe websitewww.craigslist.org - if you're looking for a donor carwww.ebay.com - all the used parts you could ever wantwww.forced4.com - lots of 2.3 performance partswww.esslingeracing.com - more 2.3 performance stuffwww.racerwalsh.com - even more 2.3 performance stuffwww.summitracing.com - cheapest forged pistons I've found - P/N - TRW-L2500Fwww.rockauto.com - dirt cheap namebrand auto partswww.boostvalve.com - aftermarket boost valvehttp://www.allfordmustangs.com/forums/2-3l-tech/71687-how-turbocharge-your-normally-aspirated-2-3-a.html Цитата
Артифас Опубликовано 21 Апреля 2015 Автор Жалоба Опубликовано 21 Апреля 2015 You can install a turbo on a N/A 2.3 but don't turn the boost up past 5-6 psi. If you do, the pistons will disinegrate! And, even running that low psi, they probably won't last very long anyway! True turbo motors came from the factory with forged pistons. Forged pistons will take the heat and pressure of forced induction. N/A pistons are made of cast metal. They're very brittle and simply can't take the heat and pressure. So, if you're going to rebuild your motor, simply replace the cast pistons with forged units. You'll also need to fabricate some sort of oil drainback for the turbo. Oil is fed into the center section of the turbo from the top, circulates and drains back into the oil pan. 2.3 turbo blocks have a threaded drainback hole thats tapped into the block just above the oil pan to accomplish this task. If you have a bare N/A block, you can drill and tap this boss in the block and acquire the appropriate brass fitting to screw into it. The fitting can be found on any turbo block in the junkyard and occasionally they're for sale on Ebay. Another alternative is to tap into the oil pan, above the oil line and run a hose from the bottom of the center section to the pan. That's it for the actual shortblock. True turbo heads have a different combustion chamber and port configuration than N/A heads along with exhaust valves made from a stronger metal known as Iconel.Turbo motors use a Vane Air Meter and larger 35# fuel injectors for fuel and air delivery. Both can be found in the junkyard or on Ebay. To provide the appropriate amount of fuel to the injectors along with the correct metering of air, you'll need the right computer. An LA2 or LA3, found in '87-'88 Thunderbird TurboCoupes with 5-speeds is the one you want. An LB2, LB3 and PE will also work. The LB series is for TC's with automatics and the PE, the most aggressive of all computers, is found in the Mustang SVO. The computers themselves are easily swapped. You'll also have to repin the wiring harness computer connector. Most people give up here because it sounds like such a daunting task! It's probably the simplest procedure in the whole swap. There are several websites that give you step by step instructions. In addition, you'll need either a factory or aftermarket boost controller to control your boost pressure. A good idea would be to add a 255 lph fuel pump to provide the additional fuel that's needed. Too many turbo applications have died due to lean conditions!By far the cheapest, most thorough and simplest way to add a turbo to your N/A Mustang is to purchase a donor car and swap everything over. The first choice would be a '87-'88 Thunderbird TurboCoupe. They come with a factory 195 hp turbo'd 2.3, T5 and 8.8 rearend with disc brakes and 3.55:1 gears. All this can be easily swapped into a Mustang. In addition, you'll have everything you need along with a zillion nuts, bolts, fasteners, etc. There are many other parts that can be swapped into a Mustang as well. Interior pieces, suspension pieces, brakes, the list is endless. Here's the kicker. '87-'88 TC's are a dime a dozen, at least on the West Coast. $500 will get you a good running, high mileage TC. And as you know, 2.3's are pretty much bulletproof! The iceing on the cake is, what you don't use on your project, you can resell on Ebay or any of the message boards dedicated to 2.3 turbos. There's a good sized market out there for used TC parts. Your $500 will be recouped in no time!If you can't find a '87-'88 TC, the next best thing would be a '83-'86 TC, followed by an '85-'89 Merkur XR4ti. There are turbo Cougars out there that are also good candidates. I believe '85-'86 are the years for them. Of course an SVO would be the ultimate! However, they're pretty rare and you probably wouldn't want to part one out. Below is a list of websites of both vendors and just regular Turboforders that offer tons of information. I hope this addressed some of the basic questions of turboing a N/A 2.3. It really isn't a very hard swap. If you have some basic mechanical ability and a good set of handtools, you can easily perform this swap. You'll learn a few things along the way and the sense of accomplishment you'll acquire will make it all worthwhile. Oh, and you'll be amazed at how quick you car is gonna be!List of websites:www.stinger-performance.com - wiring conversionwww.flemworld.com - wiring conversionwww.turboford.net - turbo 2.3 websitewww.turbotbird.com - TurboCoupe websitewww.craigslist.org - if you're looking for a donor carwww.ebay.com - all the used parts you could ever wantwww.forced4.com - lots of 2.3 performance partswww.esslingeracing.com - more 2.3 performance stuffwww.racerwalsh.com - even more 2.3 performance stuffwww.summitracing.com - cheapest forged pistons I've found - P/N - TRW-L2500Fwww.rockauto.com - dirt cheap namebrand auto partswww.boostvalve.com - aftermarket boost valvehttp://www.allfordmustangs.com/forums/2-3l-tech/71687-how-turbocharge-your-normally-aspirated-2-3-a.html Спасибо Цитата
Артифас Опубликовано 21 Апреля 2015 Автор Жалоба Опубликовано 21 Апреля 2015 Кстати про распредвал ни слова ни написали,насколько я знаю у турбо мотора должны быть другие фазы.Короче проще оставить эту идею или как пишет Американский автор-,,найдите донора с 2,3 турбо мотором,, Цитата
root Опубликовано 21 Апреля 2015 Жалоба Опубликовано 21 Апреля 2015 (изменено) Кстати про распредвал ни слова ни написали,насколько я знаю у турбо мотора должны быть другие фазы.Распредвал с лифтерами от Ренджера 2.5 или лучше от турбокупе.БУ на ибей от 100 долларов за кит.Фазы можно двинуть разрезной шестерней.Управление и настройка - главный вопрос.Короче проще оставить эту идею или как пишет Американский автор-,,найдите донора с 2,3 турбо мотором,,Короче чтобы это сделать надо сначала сделать капиталку с новыми коваными поршнями. Изменено 25 Сентября 2015 пользователем root Цитата
dimon Опубликовано 21 Апреля 2015 Жалоба Опубликовано 21 Апреля 2015 Все поиски истины на форуме привели к мысли, что мотор хорош таким, какой есть. Цитата
root Опубликовано 21 Апреля 2015 Жалоба Опубликовано 21 Апреля 2015 Все поиски истины на форуме привели к мысли, что мотор хорош таким, какой есть.Особенно если он есть турбо))) Цитата
Артифас Опубликовано 21 Апреля 2015 Автор Жалоба Опубликовано 21 Апреля 2015 Кстати про распредвал ни слова ни написали,насколько я знаю у турбо мотора должны быть другие фазы.Распредвал с лифтерами от Ренджера 2.5 или лучше от турбокупе.БУ на ибей от 100 долларов за кит.Фары можно двинуть разрезной шестерней.Управление и настройка - главный вопрос. Короче проще оставить эту идею или как пишет Американский автор-,,найдите донора с 2,3 турбо мотором,,Короче чтобы это сделать надо сначала сделать капиталку с новыми коваными поршнями. управление я б на январе собрал ,но теперь судьба мотора таскать автобус)) Цитата
root Опубликовано 21 Апреля 2015 Жалоба Опубликовано 21 Апреля 2015 За 3 часа судьба мотора изменилась? Цитата
tolik2466 Опубликовано 21 Апреля 2015 Жалоба Опубликовано 21 Апреля 2015 я думаю тс хотел чтобы перло Цитата
Артифас Опубликовано 22 Апреля 2015 Автор Жалоба Опубликовано 22 Апреля 2015 За 3 часа судьба мотора изменилась? я думаю тс хотел чтобы перло Зачем мотору турба? )))так же в личном парке есть жопавоз Sierra и на нее пиготовлен V6 2,9 .вот и думал может поставить в6 в бус а к 2,3 прикрутить турбинуи в сиерру Цитата
tolik2466 Опубликовано 22 Апреля 2015 Жалоба Опубликовано 22 Апреля 2015 какой бюджет планируется на постройку? Цитата
Артифас Опубликовано 22 Апреля 2015 Автор Жалоба Опубликовано 22 Апреля 2015 какой бюджет планируется на постройку?на постройку чего именно? Цитата
root Опубликовано 22 Апреля 2015 Жалоба Опубликовано 22 Апреля 2015 Сделать 2.3 турбо из атмо и поставить в Сьерру минимум $3000 надо... если готового турбового донора нет.А как оно будет жить с коробкой Сьерры вообще непонятно. Цитата
Артифас Опубликовано 22 Апреля 2015 Автор Жалоба Опубликовано 22 Апреля 2015 Сделать 2.3 турбо из атмо и поставить в Сьерру минимум $3000 надо... если готового турбового донора нет.А как оно будет жить с коробкой Сьерры вообще непонякпп сиерры MT 75 выдерживает до 400сил,проверянно Цитата
root Опубликовано 22 Апреля 2015 Жалоба Опубликовано 22 Апреля 2015 Сделать 2.3 турбо из атмо и поставить в Сьерру минимум $3000 надо... если готового турбового донора нет.А как оно будет жить с коробкой Сьерры вообще непонякпп сиерры MT 75 выдерживает до 400сил,проверянно И МТ75 прикручивается к этому 2.3 без доработок? Цитата
dimon Опубликовано 22 Апреля 2015 Жалоба Опубликовано 22 Апреля 2015 А какое передаточное число ГП у Сиерры? Цитата
Артифас Опубликовано 23 Апреля 2015 Автор Жалоба Опубликовано 23 Апреля 2015 Сделать 2.3 турбо из атмо и поставить в Сьерру минимум $3000 надо... если готового турбового донора нет.А как оно будет жить с коробкой Сьерры вообще непонякпп сиерры MT 75 выдерживает до 400сил,проверянно И МТ75 прикручивается к этому 2.3 без доработок? 2,3 сделан из 205 блока форд пинто,он же OHC 2.0 Цитата
Артифас Опубликовано 23 Апреля 2015 Автор Жалоба Опубликовано 23 Апреля 2015 А какое передаточное число ГП у Сиерры?естьразные редуктора от 3,42 до 3,98 вроде Цитата
dimon Опубликовано 24 Апреля 2015 Жалоба Опубликовано 24 Апреля 2015 А какое передаточное число ГП у Сиерры?естьразные редуктора от 3,42 до 3,98 вродеНа 4:1 ехать будет и без турбо. А сколько ставят с турбо, лучше заранее уточнить. Цитата
Любитель Фордов Опубликовано 24 Апреля 2015 Жалоба Опубликовано 24 Апреля 2015 2,3 сделан из 205 блока форд пинто,он же OHC 2.0они действительно очень похожи, но это не так. Цитата
Любитель Фордов Опубликовано 24 Апреля 2015 Жалоба Опубликовано 24 Апреля 2015 А какое передаточное число ГП у Сиерры?естьразные редуктора от 3,42 до 3,98 вроде3.14-3.91 Цитата
tolik2466 Опубликовано 24 Апреля 2015 Жалоба Опубликовано 24 Апреля 2015 какой бюджет планируется на постройку?на постройку чего именно?именно того что ты задумал это будет не свап а именно стройка Цитата
Артифас Опубликовано 24 Апреля 2015 Автор Жалоба Опубликовано 24 Апреля 2015 какой бюджет планируется на постройку?на постройку чего именно?именно того что ты задумал это будет не свап а именно стройка я же говорю у меня две машины и в обоих меняется двигатель,так не понятно бюджет сиерры или автобуса Цитата
